Medskipper
Year after year I put new zinc shaft anodes on and the following year on lift out there is never a trace of them! I suspect that they fall off after just a few short months leaving me no protection or certainly less as I also use hull and trib tab anodes in a my salt water environment.
Last year I tried a little experiment! I dabbed a little anti foul
on the bolts and thin area where the shaft anode clamps together. This year when my boat was lifted both anodes where still bolted on and the main guts of the anodes, i.e. the thick middle bit had almost gone, so I now know that I can make sure of shaft/prop protection for the whole year just by covering the bolted areas! Maybe you already knew that, but if you didn't try it!
All the best
Barry
All the best
Barry
