Lakesailor
Small boat, day sailing, single handed, from swinging mooring.
Tried both. Hank on is a pain. Roller so much easier. Had both reefing and furling systems, but only used them as furlers.
Being able to sail up to the mooring and furl the sail in a couple of seconds made the whole procedure much easier. Especially as the small foredeck was then clear for mooring.
Leaving the mooring is easier as well if you can leave deploying the headsail until you are on the tack you want. Otherwise you are into rigging a slipping mooring line and timing it for when the boat has yawed the way you need and you have been able to back the headsail to get the right heading.
For just ambling about the slight lack of pointing is irrelevant. Not clonking a nearby boat is much more important.
(Yeah, I know you can use your motor)
