Do you reckon i could get this working?
ashley
25 Jan 2003
\'d After Dark
I thought i might have to hide "land" switch though.
The wife might use it when she panicked when the headland dissapeared over the horizon!
poriordan
13 Jan 2005
Better see first if you can get a little bit more info on it Ashley. Relay contacts might be your main concern, if hard wired or electronically operated. Electronically operated - forget about it, and even hard contacts might need additional relays to handle the load of steering solenoids etc. Might be a lot of trouble in the long run. If you do go ahead with this, get back on here and leave us know what happened !
PaulJ
7 Jul 2001
Ipswich
Are you serious or is this a wind up? This item is only the autopilot control panel that goes into the coaming above the instruments. It is NOT the autopilot. In any case it would not be suitable without a mountain of other gubbins to go with it. Forget it!
ShipsWoofy
10 Sep 2004
I used to have an open mind but my brains kept falling out.....
Oviously /forums/images/graemlins/smile.gif
