[70521]
Halyard tension always taken off when leaving the boat. Adjusted as necessary when sailing, having new sails you can feel the difference between a loose and taught sail even when they are furling.
With a Luff Groove sail on a furling - please explain what advantage there is in different tensions ? Given that most furling gibs are cut to furlers and not same a hanked on ... second you have a clean foil entry to the sail unlike a hanked on ...
I make sure mine is taut all season ... and that's it. If it was my race boat - sold on now - that's different as its hanked on anyway.
I have a hydraulic oneyes me too we have a hydrolic backatay
Our Moody is masthead but in her youth she was raced, she has a 32-1 purchase on the backstay, (8-1 tackle x2x2cascade) we apply tension depending on heading and windspeed, we only have dacron cruising sails (the high tech. ones do not furl so are kept above the garage) so we also tension the genoa halyard for going upwind, again dependent on wind strength, easing it to reach or run and release the tension to a second mark on the halyard before furling. The shape changes are quite obvious and effective, the boat does appear to sail well for its size and shape.
I thought everyone did this, for me it is part of what makes sailing satisfying.
I can measure improvement in performance as I adjust halyard tension . As with car position I can get better air flow . Different tension for different wind speeds. And some times sea state.With a Luff Groove sail on a furling - please explain what advantage there is in different tensions ? Given that most furling gibs are cut to furlers and not same a hanked on ... second you have a clean foil entry to the sail unlike a hanked on ...
You are a real sailorI can measure improvement in performance as I adjust halyard tension . As with car position I can get better air flow . Different tension for different wind speeds. And some times sea state.
I also use different tension for beating and reaching.
Similarly I adjust kicker tension and twist on the main.
If I am leaving the boat for more than a week or so, I take the sails off.
'Why? And is it a small boat?
Taking our sails off is a hard work project, and takes at least half a day if two up, almost impossible to do for one person. Vertical battens are a killer on the jib, and weight plus long battens and 3 reef lines makes the mainsail slow. And folding needs help.
So sails left on all year round, though old jib on during winter. Survived plenty of F10+ so far.
And almost never adjust jib halyard. With foil and laminate sail, halyard is generally never very taut to get best shape. So no need to ease when leave it.
Ramming on the jib halyard tight is often not a good thing - look at lots of Olympic dinghies with slight horizontal creases, only heaved down tight when full survival mode.
I wonder how many boats actually have a way of adjusting back stay tension easily?
Much like what I said. It is the effect on the furling gear that chiefly interests me. Although I grease my gear according to the instructions, the difference in effort when easing the tension is all too obvious. Even with a laminate jib, it makes sense to relax the sail when not in use, something I also do with the mainsail foot. It is not as if either task involves much time or effort.I do not really get this, possibly because I come from a racing background, but surely there is a direct relationship between the useful life of a sail and the proportion of time it is under tension, if you ease the halyard tension before you furl ( as recommended by Furlex and many others to extend the performance of their gear) you are only subjecting the sail to tension for the time you are actually sailing, in our case perhaps 30 days out of the 50 odd we are on the boat in a season, perhaps only a total of about 100 hours or less instead of over 4000.
2.5%? That is a shock, I thought I had more fun than that in a season.
I can understand that if you do not study sail shape or performance it is something else to do, but would you ride your bike on flat tyres?
I let the tension off my jib after sailing just to save stretching it. The main and jib are easy to take off but putting them back on is another game. The jib has an UV strip and is rolled tightly so during the season not a problem. During winter it is taken off. The same really applies to the main as well.Just interested.
I'm wondering if mine is worthy of my posh new Spinlock clutch or just tie it off .
When I had hanked jibs, apart from up and down I adjusted them quite a lot with satisfying results.
