PaulRainbow
Our engine battery was a Numax 24MF 80ah and gave good service for several years, in April I replaced it with a new battery of the same make and spec. from Tayna. The battery was on the boat charger until launch in May and since has only been charged by the alternator. I noticed that the new battery did not seem to have the oomph when starting that the old one used to have and when I measured the voltage after about a week at rest it was showing 11.7v. I took the new battery out, brought it home and put it on charge using the Optimate 'intelligent' 3 stage charger that my wife used for her sports car. After 2 days the charger was showing that the battery was fully charged, the voltage when disconnected from the charger was 12.87, after an hour it was 12.62, +4hrs it was 12.48, +24 12.40 and +48hrs down to 12.33.
This suggests to me that this is defective and simply not holding charge. Before I contact Tayna can anyone confirm that I am right to think this battery may be duff?
The Optimate is a great little charger for leaving on your wifes sports car over Winter, or things like motorbikes, jet skis etc that sit around for months on end, it will stop the batteries from dying. It is not suitable for fully charging your Numax battery, it has a max output of 1A.
You need to fully charge the battery with a decent charger, leave it to rest, then check it for its discharge rate. It may, or may not, be knackered, but you need to charge it and check it to find out.
