Do charts need to be updated?
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
With electronic positioning here to stay.
Do you:
- Sail by what you see and accept the presence or removal of a navigation mark and use a chart to give you a graphical representation of where you are and your track so you don’t run aground.
- Feel uncomfortable if your chart isn't up to date, and update before every passage.
- Update only if the passage is to somewhere new or unvisited for a year or two.
- Treat update as a winter job.
I would argue that unless you update for every trip out, you are sailing by what you see, so you should never bother with updates, just replace the chart every five or six years.
janeK
11 Sep 2003
W/SW - GB
I update each chart as a winter job normally, but if the chart is 6+yrs buy a new one.
Charts are still on the chart table even though there are electronics on board as I prefer to view the 'bigger' picture as well.
Position is also plotted too on the chart.
david_bagshaw
5 Jun 2001
uk
depends on where i am
ie busy muddy / sandy estuaries schelde etc, new chart every year
eider estuary get buoy position up date from web / harbour master for certain day before
Baltic, western where a lot doesn't change frequently, yearly update.
Robin
30 May 2001
high and dry on north island
I scan the Notices for anything WORTH updating but rarely have to. So much is changes to areas way off our normal routes or to depths where we should never be or those still deep enough to ignore. I will change MAJOR light changes but minor buoys in obscure areas not so, and we do carry the excellent French Almanac with all the latest buoy/light information. Major bouy changes will be updated on our plotters to by using the 'mark' feature and the symbols available. A really major chart change that I think is important will mean I buy a new chart, like for Channel West when Ushant TSS was moved 2yrs back.
I should add that for the most part we use Imray charts and download updates from their website which are printed out and carried on board, just not actually put on the chart unless important. Whether these updates are ever looked at again, well maybe.....
Greenwichman
14 Nov 2004
Tollesbury
Depends on where you sail. Here on the east coast the Thames Estuary and its approaches are constantly changing; easiest is to buy a new chart each spring and keep an eye on the Notices To Mariners throughout the summer. Over on the Devon coast some years ago I used 10 year old charts with confidence; rocks don't move like shingle and sand do. /forums/images/graemlins/grin.gif
VicS
13 Jul 2002
Strictly the answer must be that you must have fully up-to-date charts for the area in which you are sailing.
The extent to which you ignore that is up to you but if you had a mishap and it came to light that you were using old black and white charts that you bought back in 1960 for 10/6d you may well find yourself on the wrong side of the law, your insurance company, and the RYA. If a crew member was seriously injured, or worse, you could be in deep manure.
Having said that...etc.etc..the boat I have regularly crewed....etc..etc... and there have been times when the lack of an up-to-date chart has stopped us doing something we intened to do. Going through the passage inshore of Cap de la Hague light for example.
ianwright
Home: Peterborough, Mooring, Heybridge Basin
If the mishap involved hitting something that was on new charts but not on the old you might have a point. But as my 10/6d charts ARE updated and provide all the information I require there will be no problem. Information is what counts, not newness.
IanW
starboard
22 Dec 2003
N5533 W00441
In an ideal world where time and money not a problem...yes. However personally I prefer to buy good condition second hand charts uncorrected from www.chartsales.com and for my money may get 4 charts covering the same area with greater detail than one new chart that would be a compromise covering the area of the 4 more detailed charts. This should always be backed up with an uptodate almanac wich would give the latest detail on lights and buoyage etc. In practice you will find rocks tend not to move and it is quite rare that a new one will be discovered. If you note the survey dates on many charts you may find even the most up to date chart the seabed was last surveyed by HMS Trafalgar in 1875.
Good luck
Paul.
ashanta
28 Apr 2003
I update what I feel is relevent to me but I glue the notices from Imray on the bottom of the chart as they are when you buy a current edition. After so many years, if the number of changes are getting high then renew the chart with the latest edition.
Regards.
Peter.
VicS
13 Jul 2002
Re: Updating very old charts
I'm surprised that you have found an updating service for charts that old. The Notices to mariners only apply to the latest edition.
If you were using tracings to do it - fair comment ..... but if you do it the old way by plotting position - then the age of the chart makes not a shred of difference - EXCEPT where datum change occurs...... even then a position is a position and you are generally navigating within a tolerance - not single metres etc.
As an ex navigator setting courses etc. for ULCC tankers etc. - who really DO have to worry about banks / depths in English Channel and North Sea etc. - where the average yottie would not bother to read an e/s ..... on my boat make do with cancelled charts and electronics ..... updating charts - rarely - only really when I actually see and have an object new / moved where I'm going .... no panic - just a note on chart to watch for it next time around ..... !!
I commend those who do correct their charts - but also understand those that don't .....
/forums/images/graemlins/shocked.gif
roger
Overwinter in Sweden, sail in Northern Baltic, liv
The short answer is yes you do need to update - if it is possible.
For Holland you must be veryy careful as the sands move about and that goes for North Sea Germany as well.
The Danes are removing buoys rapidly.
The Finns are changing to WGS 84 and altering buoyage like crazy.
In general it depands how close you sail to the bottom or the bricks. If you leave wide margins for error and avoid nasty conditions etc. You can be a bit more lax over charts.
In Finland last year I had a nasty half hour east of Hanko where the recommended track and the buoyage had altered - and the chart datum. Luckily the visibility was good.
ianwright
I got caught out going to Vlissingen three years ago. Brand new imray chart and all,,,,,,,,
The Duerloo buoys
had been removed. This was announced in NTM the week after I left home. Fortunatly the old waypoints on the gps still worked and a nice lady on the vhf was reasuring.
/forums/images/graemlins/smile.gif
IanW
duncan
Home mid Kent - Boat @ Poole
old electronic charts - new almanac each year
the above, with radar in reduced visibility, effectively means I am navigating buoyage by what I can see and the coastline by what's always been there!
tcm
11 Jan 2002
Caribbean at the moment
Re:yep
also, of course, doing the updates doesn't mean that every single thing that's supposed to be there...actually is there on the day/night you're there. Much better to look for a few lights etc and not to be too suprised if some of them aren't there at all...
