DIY water maker
ongolo
5 Aug 2003
Hi all,
does anyone know a site or plans for making a RO water maker?
Has anyone done this?
thank you
regards ongolo
No. But I have done a lot with them.
In its simplest form it should not be too dificult, the only parts you would have to buy is the membrane around 3-400 euros each depending on how much capacity you want. You could make a pressure vessel depending on your facilities and you will have to buy either a Clarke type pump or a Cat pump (used in car washes) to provide the high pressure feed (900 psi) - if you mount this below the w/l you can get away without a feed pump. The flow rates can be got from google as I cant remember them off the top of my head. A restriction valve and, a pressure gauge and a flow gauge and you are done.
You will of course need a lot more bits than that but thats the basics
It would be a project thats for sure. Be carefull with 900psi water though - blow the end cap off your pressure vessel and it could go through you or the side of your boat!
Good luck with it
Paul
<hr width=100% size=1>Paul
<A target="_blank" HREF=http://www.polarity2.com>http://www.polarity2.com</A>
Class II OSTAR/Transat 2004
I am currently installing a DIY watermaker in my yacht in durban (south africa)
the membrane and pressure vessel was supplied to me by a frend. The pressure vessel made in SA but the membrane imported. The outout is approx 80 lt/hour and is either mains electricty driven of belt driven from main engine. I have mine mains driven and have fitted a mains alternator belt driven from my main engine. PM me with contact details and I can help with supply of parts you cannot get in namibia.
