This week I coppercoated my keel and rudder as an experiment and training exercise. I thought I would make some public notes for the benefit of others and maybe myself should I do the rest of the hull in a year of two.
Summary:
It is hard because once started there is no option to rest-up or postpone and the epoxy paint is temperamental stuff to work with.
Mistakes Made:
Summary:
Mistakes Made:
- Trying to cram the job into a summer special 7 day haul out. After preparation of two days I had a two day weather window for application which did not materialize even mid summer.
- Epoxy primer paints come in two varieties, solvent and water based. Don't buy the solvent variety unless you can allow for 7 days so that the base layer can vent off its solvent otherwise you risk the coppercoat trapping vapour and bubbling. In British terms this means don't buy GelShield 200.
- I should have spent a few extra days filling & fairing minor dings in the keel profile because unlike a regular anti foul application I will now have to live with the finish for 10 years.
- If you want a performance finish then buy 50% more paint that the manufacturer specifies in order to allow for some post application burnishing back to a slick finish. I have noticed over the years that many a coppercoated hull has a stippled finish probably because amateurs are not familiar with the unforgiving handling characteristics of a 2 part epoxy paint.
- I did not key the epoxy base coat (non coppercoat) enough and as a result the first coppercoat layer did not transfer down well as the roller skidded over the surface. Realizing my mistake mid pot I quickly applied a deeper key with an orbital sander before the pot cured. This would not be a viable correction on a conventional whole hull job.
- There is no option to visit a DIY store for extra supplies mid job, you need all materials for the whole job e.g. 6 paint roller sleeves (not hairy ones) and paint trays and lots of plastic beakers if mixing mini batches. B&Q do calibrated clear plastic cups.
- The paint is very heavy to mix, think sloppy cake mixture once the mass of the copper is added. A wooden slotted spoon from the galley was the perfect stirrer (need to find a replacement before Swmbo visits).
- The copper settles very quickly post mixing so stir again every time you top up the paint tray.
- Unless you have a large application team I doubt a DIYer can roll on a standard 1 liter unit of coppercoat before the pot begins to cure hence you will need something to weigh equal measures of the coppercoat powder. I would pre-bag mini portions of the coppercoat powder at home in heavy duty freezer bags ahead of the job. The copper powder bags supplied are very well sealed probably for health reasons.
- The dry copper is very fine, think icing sugar or flour. Defo need a top notch breathing mask when handling this stuff and shelter from the wind.
- I reckon a DIY team should be 3 strong, one mixing, dispensing and re-stirring, the other two rolling on.
- The manufacturer of Coppercoat cannot be arsed to specify the max percentage of thinners on the bottle's label which contains mainly cut & paste health and safety wibble. 10% is too much, reckon 3% to 5% is ok. You will need thinners for ease of application and a smoother final finish.
