ghostlymoron
Can you convert a sea-water cooled Yanmar 3gm30 to indirect cooling?
Yes. you can do anything you want, cost is the issue and your engineering expertise.Can you convert a sea-water cooled Yanmar 3gm30 to indirect cooling?
I had the same engine on the boat 10 years ago fitted with a Martec cooler it was CARP and could not cope. The other problem with it was that it relies on a poxy little electrical pump and to be safe you have to fit an alarm to tell you when it fails rather than relying on the engine temperature alarm. I eventually bought Yanmars conversion kit about a grand from memory problems solved.
Any idea where I can get a manual - preferably free download? The reason I want to convert is to allow hot water supply.The Yanmar Workshop Manual for GM engines has a chapter on converting to indirect cooling. For the 3GM30, the kit of parts for the modification is No.728374-99510.
I expect that it would be wise to be seated when enquiring the price.
How have you plumbed in the calorifier? Is there a high enough flow rate?
Been there. Cost benefit ratio is questionable. Same engine was 15 years old (raw water cooled) no significant corrosion.Can you convert a sea-water cooled Yanmar 3gm30 to indirect cooling?
