Seven Spades
Well the saying is you learn something new every day. I had never heard the phrase "Dipping an Eye" but this is a really fantastic video.
These days dipping eye is problematic as each pontoon cleat appears to have multiple figure of eights, multiple lines and multiple round turns, plus many locking hitches. Neatly attaching one’s mooring line to the cleats is long dead from what I see these days.
Good video.
This is great when leaving, but can lead to chafe if you do it for the whole stay so not best practice.We rarely secure to the pontoon cleats but instead return our lines to the boat as it keeps the pontoon cleats clear and we can slip our mooring with everyone onboard
I’ve been in several marinas where it would be a problem in a day. Not having seen a problem isn’t evidence there isn’t a problem. Good practice exists so you don’t have to see all the problems first hand!Been doing it for years and never had a problem but then we are rarely in any one place for more than two or three days at the most. I think you would need to be in a mooring do a long time before chafe becomes a problem. I am talking marina berths here.
Movement of the boat. With the rope effectively loose on the shore cleat there is more movement in the rope unless you tie your boat uncomfortably tight. I know a lot of people do tie off with their lines tight but that’s a whole other issue!Provided that both parts of the line are brought back aboard through the same fairlead, and made fast on the same cleat, how is it going to generate chafe?
So how is that going to be any different from having a spliced eye onto the cleat?Movement of the boat. With the rope effectively loose on the shore cleat there is more movement in the rope unless you tie your boat uncomfortably tight. I know a lot of people do tie off with their lines tight but that’s a whole other issue!
Because you don't drop the eye over the cleat you pass it through and over. It is the same when tying off to a mooring buoy you should always take an extra turn around to minimise chafe.So how is that going to be any different from having a spliced eye onto the cleat?
Ships seem to manage perfectly well by just dropping spliced eyes over bollards, without suffering chafe. Don't muddy the waters by bringing in mooring buoy arrangements, which is a completely different situation.Because you don't drop the eye over the cleat you pass it through and over. It is the same when tying off to a mooring buoy you should always take an extra turn around to minimise chafe.
Very true but I do have a reasonable amount of qualification/experience and I too have moored in some lively marinas and no sign of chafe after a day, and I always leave sufficient slack in the lines to let the boat move. Not saying I would do this in a longer term mooring, just a relatively brief visitor mooring. Whilst I acknowledge your point we can just agree that we have differing views on the matterI’ve been in several marinas where it would be a problem in a day. Not having seen a problem isn’t evidence there isn’t a problem. Good practice exists so you don’t have to see all the problems first hand!
