Refueler
The mobility scooter "Shop Rider" as in the Utube are quite expensive new. (3000squid plus) However they do become available second hand as the oweners tend to get a better offer of residence (heaven) So keep an ear out for availability. ( 5 to 10% of new price if you are lucky)
The wheels on the transom work out very well for me. I can drag the dinghy by the bow from the parking spot for the shoprider to a poinnt with bow over the water. I just flip the dinghy over and drag into water. On recovery drag the dinghy high enough out of the water that I can then flip it upside down and drag it up a few feet to hook on the shoprider. For the first really steep part of beach I walk next to the shop rider while driving it cos my 100kg are a bit too much load. It will do it.
Unfortunately there is a tendency with mobility scooters to go light weight folding with lithium batteries and smaller wheels. Great cos you can get them into a larger 5/3 door type car. I saw a lady recently with a electric hoist fitted into her little car to stow the scooter. Great. But I suspect the smaller scooters will not have the larger wheels excess power you might need. The shop rider must weigh 150kg or so. (with 2x 40 AH deep cycle LA batteries)
Might suit Nigel but the shoprider has a differential drive to back wheels. So not great for difficult traction.
Incidentally the shoprider brand comes in essentially 2 sizes. The bigger one I use has longer wider wheel base while the smaller version more suitable inside a shop is narrow shorter and has anti tip tramp wheels at the back. Is inclined to lift front wheels especially if you have the seat pushed back.
I have a big one and a small one. Small one has enough power to tow dinghy but can be a bit more unstable. I did however take off the tramp wheels when fitting a tow hook and managed to tip it right over backwards. Quite spectacular with me sitting still in seat stopped by head rest on ground. Front wheels up up wards. (no harm done. ( 2 scooters? his and hers, getting practice for old age) In both cases owners were glad to get rid of scooters after owners passed)
Both scooters charged by 2x 10w solar PV panels in series no controller. ol'will
I've ben searching online for a suitable E-Quad ... as the trikes wheels as too small for my ground. I also need the off-road tyre tread. I can get a gasoline powered 125cc Quad for about 900 quid here ... but I wonder if it can actually pull anything up the incline I have from the water ...
E-Powered I found over here start for a lot less power at 1600 quid !! and only capable for a chiold ....
Caravan movers are no good on my ground as well ..
Looks like snow chains on my Lawn Tractor again.
