Dinghy fendering suggestions?
22 Apr 2009
Just driftin
I have just bought a tatty old dinghy to replace the one that was stolen & have had to strip away the wood from around the gunwale because it was rotten.
I would like to replace it with a nice rubber bumper strip but that is not cheap & a friend suggested using the plastic type lagging for pipes that you can buy from DIY stores for peanuts.It looks like amazing stuff & could be stuck on simply with that instant grip glue type stuff that you can also buy from there & is applied by a gun the same as silicone rubber but does it do a good job,has anyone tried it?
Any other suggestions gratefully welcome.....
Clear (or coloured if you prefer) poly pipe can do a good job, cut a hole in the outside & simply screw thro a washer into the boat. The insulation is cheap but will probably need replacing every year or two as it is easily nibbled away by abrasion, poly pipe will last a great deal longer.
Old poly prop rope (local fishermen will probably have loads of suitable bits for a pint) looks more traditional & can be screwed or tacked thro the inside strands only to hide the fastenings.
Round our way, the seagulls eat the cheap pipe insulation and **** it onto the deck ...
Mice eat the pipe insulation in my loft, but I guess that would not be a problem with a dinghy ....
Incidentally, I offer free to anyone who wants to develop it my cunning plan to manufacture pipe insulation incorporating mouse-poison.
Foam insulation is grand. Since taking the picture I have drilled through the gunwhale and fitted cable ties around it to locate it more securely.
A bit of old rope looks nice. Tried various ways of fixing it but laced on as in the pictures has proved to be the best
If poly pipe is the stuff I saw in the DIY centers around here the other day searush I thought it a bit hard & screwing it to a flat gunwale would mean a very small area of contact as it is hard & round.I agree that the insulation stuff did'nt seem very manly so for now am continuing on looking.Thanks.
I will reply to this one in reply to all of you who suggested rope in the hope that it will do.
The problem is vic my dinghy is fiberglass & only about 3/16" thick so rope round the edge would still leave an unpleasant top that would be sharp & nasty......needs a more substantial capping rail.
you certainly did'nt skimp on diameter!:D & the stuff underneath that looks like quite good stuff but obviously very small diameter looks more like the stuff I need lakesailor.
Looks like a good practical down to earth sort of dinghy........maybe it's about time we held a dinghy beauty competition:D
