Alan Hensler
Was planning on topping up the diesel tanks shortly they are about 50 % full.
Then had a very interesting email from Marine 16 about not filling tanks up for winter
This is the article:
Modern diesel is highly unstable, it’s been refined to within an inch of it’s life to remove the sulphur and now it has 7% plant oil along with animal and cooking fats. It degrades very quickly producing sludge that ends upon the bottom of your tank. The stability improver and antioxidant we blend into Marine 16 Diesel Fuel Complete (DFC) helps slow some of the degradation, but it cannot be fully prevented or reversed, would you get a blackened banana in the fruit bowl and try and recover it? No? you can’t, it’s same with diesel, it just doesn’t go as black.
So here at Marine 16 we recommend running the fuel tank down to as empty as possible. Get as much water out as you can, if you can, and put in a kill dose of Diesel Bug treatment (DBT) to kill any bug over the lay up that might try and take refuge in your tank. You can stop the moisture entering the tank by fitting a desiccant breather on the vent. This will dry the air as it is drawn into the tank so it cannot condense on the sides. Available on our website soon.
Additionally add a dose of Diesel Fuel Complete (DFC), even if you have been using it. From our research with fuel testing laboratories throughout this year we have improved DFC with an additional antioxidant in the blend in an attempt to mitigate the continued degradation of the FAME (The bio bit in the Diesel) which leads to carboxylate acid. We can’t stop the degradation, see above about the banana, but along with the dispersant in the blend this will help reduce deposit formation on the bottom of the tank.
When you return in the spring, drain any water from the drain cock or push a pipe down the filler to the bottom to try and draw off any accumulated water, or fit a diesel dipper over layup that can do it for you. If you invested in a desiccant breather there be should be very little anyway.
You should now be able to fill up the tank with clean fresh diesel but don’t forget to add, and keep adding, Diesel Fuel Complete (DFC) which will help mitigate the problems of storing it longer than 6 months, which is inevitable as you enjoy the summer, especially if you’re sailing.
What do you all think of this solution????
Thanks Alan
Thanks Alan
