Giblets
You can get CO Test Kits from BES Ltd https://www.bes.co.uk/co-detectagas-test-kit-12556
Just to correct something upthread, CO binds to haemoglobin in the same way as oxygen does, so rather than simply suffocating you it actively prevents oxygen from being taken in- hence it is harmful in much lower concentrations than inert gases.
Not CO2, I suspect.
Yes CO and CO2 in my bilge , little pads going back to the alarm , my engine is below the sole boards and in a large area , so if there is an exhaust hose puncture , hole or worn then CO2 can escape and sink into the lowest parts of the bat , with CO2 is 60% heavier than air
Hot CO2 from a leaking exhaust won't be heavier than air.
were will it go it rises to the cabin floor were it is constantly cooling and spreading out, therefore getting heavier and sinking, gas in its form does not expand and spread uniformly and will find the lowest part of the boat to settle
I'm sure that means something to you.![]()
I think you will find all coded boats will need a CO2 detector in their bilges , who knows they might be onto something.
I'm very far from being an authority on this, but I think you'll find that there's no coding requirement for a CO2 alarm or detector in the bilges or anywhere else.
Small Vessels in Commercial Use for Sport or
Pleasure, Workboats and Pilot Boats – Alternative
Construction Standards
CO2 is to much a singular word and may be confusing people , a gas alarm with conforms to these standards is what I mean and apologises if I confused
8.6.2
compartment which contains a gas consuming appliance or any compartment into
which flammable gas may leak or accumulate, should be provided with a hydrocarbon gas
detector and alarm. The detector and alarm should be designed to comply with a recognised
standard in accordance with Section 8.6.1. (Refer to Section 14.5)
https://assets.publishing.service.g...ploads/attachment_data/file/282245/mgn280.pdf
Hydrocarbon fuels are basically the same as fossil fuels. ... So hydrocarbons are chemical compounds made up of hydrogen and carbon. The simplest of these is methane, natural gas. Oil is a hydrocarbon fuel because it's made up of various different compounds rather like methane, but it is liquid rather than gas.
Or, to put it more succinctly, you haven't a clue what you're on about. CO2 is related to hydrocarbons rather less than the way you're related to a giraffe.
I don't know why you posted this
CO2 is not a hydrocarbon. It does not contain any hydrogen!
The alarm that coded boats need to have in the bilge is there to detect leaking propane... which *is* a hydrocarbon.
I posted "this" because, as Kelpie explains, you're talking cobblers.
i Think if you read my post correctly before telling someoff it clearly states that CO2 is a byproduct of BURNING a Hydrocabon and the gas alarm detects all gases not all boats have propane some boats have butane . please look at the regulations which says any hydrocarbon burning , Diesel. petrol. propane, butane, methane are all forms of hydr carbon and please i do not need a chemistry lesson on Organic Chemistry I did this at University.
BURNING HYDROCARBONS GIVES OFF CO2 CO METHANE NITRATE OXIDE, ETC .you cars use hydrocarbons!! TO RUN IT IS CALLED A CHEMICAL REACTION
Hydrocarbon combustion refers to the type of reaction where a hydrocarbon reacts with oxygen to create carbon dioxide, water, and heat. Hydrocarbons are molecules consisting of both hydrogen and carbon. ... Energy is obtained from fossil fuels through combustion (burning) of the fuel.
your a pest and boring sorry stop arguing for the sake of it , when your wrong it is wiser to admit it and move on
I've never come across a CO2 alarm before. Wouldn't you get a better response from a simple smoke alarm?
