thalassa
Your solution adds complication and failure points. The extra valve can either leak due to corrosion, scale, contamination or fail to open due to electrical or mechanical failure. Personally I would be much happier with the anti syphon loop and syphon breaker properly installed, plus adequate exhaust volume to accomodate a sensible amount of cranking.
Fully support Vic's, and above advice. However, a friend's new-to-him boat engine was filled with seawater over a few days. Turned out the installation was such, that a Y-deverter with restriction was installed on the injector point. Seawater went in a narrow tube towards the stuffing box, as to lubricate the seal.
When the engine was shut off and the seacock was closed, the seawater would syphon slowly from the seal back to the injector point. He later found out there was a small valve installed on the tube to prevent this-not a practical solution.
Damage was very limited, as he spent two days changing the oil about twenty times with (at the time..) cheap oil.
