vyv_cox
I feel certain that Easistart or its equivalent will be available in Norway. It's an aerosol can of di-ethyl ether that runs very readily in a compression-ignition engine. You don't need to make any adjustments or changes to the fuel system as the Easistart is squirted into the air filter as the engine is turned over. The beauty of this is that:
a. It effectively eliminates the fuel system from the equation. If the engine runs on it you know that nothing else is wrong.
b. If there is air in the system you can often get the engine away by giving it a bit of encouragement from the Easistart. As you have found out, very little fuel is moved per revolution of the engine and the starter motor struggles. Having it run on an alternative fuel makes everything happen much faster.
In the short term the oil change will have no effect on the engine. Certainly won't stop it from starting.
Adjust your tappets like this. Count the number, usually two per cylinder, so 8 for a 4 cylinder, for example. Make adjustments so the valve checks add up to the number plus 1, so check No.8 with No. 1 depressed, No.2 with No. 7 depressed, etc. This normally works for all numbers of cylinders.
