BobnLesley
Following on from last week's post I opened our tank's inspection plate and using a Pela type pump and lots of industrial alcohol I drained and flushed several times the tank to the best of our abilities. Sadly the tank's inspection opening only allows me to reach half the tank due to a baffle plate - I could and did get the pela-pump's pipe beyond - and the inaccesible half is the low point; even transfering 100+kg from stern to bow, plus getting three people to stand on the bow's not sufficient to fully counteract that; poor installation, but hey, Greek engineers installed it so what else would I expect?
So, the tank's clean other than the bit that won't come, hopefully just a pint or two, but that's really just a guess, poured in 6 -gallon of clean diesel and a serious dollop of biocide, then bled the system and re-started. It ran at tickover/moderate revs for an hour hour then stopped. The following morning I changed the filters, re-started and got almost two hours out of it; yesterday I did nothing and today with new filters I'm up to 2.5 hours and still going.
Getting the tank out will be a b*****d of a job, at best I suspect that I'll need to haul out and remove the engine-inlet seacock; but will the current policy actually clear it eventually? I've got a week to sit and let it run and a big box of Delphi primary filters to provide replacements, though perhaps not as many Yanmar secondary/fine filters (today it's running on the old one). Can I realistically expect it to clear eventually, or am I just going to have a repeat performance in another two or three days/weeks/months?
