pvb
Read that post and you will see my reference to people who should have known better.,
I didn't see that reference. Where was it?
Excellent post from the front line. Understanding how organisations respond to incidents is important. Every single sailor who reads this forum is one step away from a careless moment that puts their name in an MAIB report. Which I sincerely hope will never happen. And without the support of such an organisation.I sailed on 'Trenchard', several times, and other Service boats. Around part of that time, the pro skipper was John Reeve - an ex- Nimrod OCU nav/instructor, assessor for the RAF's 'Mates and Skippers Tickets', and leading light/originator in the RIN's Small Craft Group - who was a consumate seaman. In 'Mentor Mode', he showed me the multiple gas safety systems and procedures installed in 'Trenchard' ( and other boats ) and 'dinned into' me the perceived risks of accumulating gas leaks. He and I, as Service aircrew, lived with explosive materials and were well aware of the vital need for unrelaxed vigilance.
I followed his guidance on the use and management of boaty gas systems for many years, content that I 'had that box ticked'. Reports of the gas explosion on 'Trenchard' at Poole Town Quay shocked me.
What I took from the MAIB report was that I could not rely on others, whose knowledge and degree of conscientiousness I could not guarantee. I've sailed many boats over the past 50 years or so. Very rarely have I witnessed an owner 'religiously' close a supply cock then let the gas in the flexible tube and burner extinguish itself by combustion. Very rarely have I observed a crewmember ensure a lit gas burner is shut off safe before making and distributing the tea. Frequently have I witnessed a gusty wind down the companionway blow out the gas flame - and the user leave it like that for a while until he'd completed something else he was doing.....
I've examined enough cracked and brittle rubber supply hoses years past their replacement date, enough corroded regulators that cannot be shut off, enough inadequately-supported brittle copper tubing to have my suspicions about 'others' cavalier approach roundly validated, over and again.
Gas can kill.
It is/can be lethally explosive, and vanishing-few on here seem to treat it with the requisite caution.
I'm wary of gas in boats. I'm wary of fuel leaks. I'm wary of fools....
#21.I didn't see that reference. Where was it?
Because if there is a density gradient it will be that way round and at depth is where there will be the least movement and thus least active dilution. None of that implies that is where all the gas is!Why do the manufacturers of gas detectors require that the sensors are placed low in bilges?
HS2 and other sulphides which create the pong are marginally heavier than air, but most dogs wag their tail with delight and this causes rapid mixing and distribution; brownian motion and/or diffusion probably deals with the rest.The distribution of the gasses in the atmosphere is really not a strong function of height and amounts to damn all over a one or two metre height difference. Think about it: the CO2 from your breathing doesn't asphyxiate the dog, but his farts - certainly much denser than CO2 - can nigh asphyxiate you even when you're standing up!
It;'s because they are lighter that they can get the velocity they need to escape when whacked (technical term) by larger molecules.I always thought that it wasn't due to density of the atmosphere but that due to the lighter molecules of hydrogen and helium a much greater proportion, despite being well down the tail of the Maxwell-Boltzman distribution, have velocity sufficient to escape the earth's gravity - aka escape velocity.
Because that is where cold gas will go first if it escapes in bulk.Why do the manufacturers of gas detectors require that the sensors are placed low in bilges?
There is no 'they'. An incident happened on one yacht 22 years ago. For some reason, you seem to want to use this as a stick to beat service sailing. You alone know why.
The best way I was taught is to lift the floor boards and fan the area with something like a chopping board with all hatches, etc open. LPG is only just heavier than air and it is soon shifted / diluted.The way to get rid of it is with the manual bilge pump: don't turn anything electric on or off if you suspect a gas leak.
Is it not a mercaptan which gives the pong to "our" LPG? That's what they use in autogas, and because it doesn't get burned in the engine, LPG exhaust smells like ... LPG, which can give rise to all sorts of misunderstandingsHS2 and other sulphides which create the pong are marginally heavier than air, but most dogs wag their tail with delight and this causes rapid mixing and distribution; brownian motion and/or diffusion probably deals with the rest.
#21.
They forgot the unicorns on the ark. Look what that led to. Gross.We all know why, because it's in the MAIB report. Sloppy maintenance, sloppy operation and a fundamental belief that following ticklist would keep everyone safe.
Many 'thanks' for defining that that technical term - There's a good chance we both attended the same 1st year thermodynamics lectures in the Clarendon!It;'s because they are lighter that they can get the velocity they need to escape when whacked (technical term) by larger molecules.
They forgot the unicorns on the ark. Look what that led to. Gross.![]()
I was across the road in the Thom Building, but spent a few years of my life in the Clarendon later on ...Many 'thanks' for defining that that technical term - There's a good chance we both attended the same 1st year thermodynamics lectures in the Clarendon!
I'm sure I've read about using a bucket, just as if 'twere water...The best way I was taught is to lift the floor boards and fan the area with something like a chopping board with all hatches, etc open. LPG is only just heavier than air and it is soon shifted / diluted.
