Design ratios for motoryacht?
laranjo123
12 Aug 2011
Hi. I would like to know what are the design ratios that are being used for motor yacht design. And also formulas for obtaning/determining the legnth, breadth, detp of motor yachts
17 Jul 2009
It has become widespread practice in recent years
to copy a house brick as the hull form,
point the front end
then stack 3 greenhouses on top,
and a playschool
a football terrace on the back end
this is all coated with 30 tons of the ugliest plastic,
a barbicanfull of brutally modern glass
6 tons of filler
a warehouse of tacky boring,dull carpet
68 tons of tacky brutal stainless steel
if you follow these guidelines
you cant go wrong
tasteless nouvo riche will be knocking on your door
as long as you dont forget to tell them how good their taste is sir
Bodach na mara
21 Aug 2002
Western Scotland
Peter's answer is all too correct, but as I assume that you want a more factual response, I will have a stab at it. It would be useful to know what lies behind the question however;
what is your starting point? (ie what do you already know?)
why do you want the information? (if you are about to design a motor yacht, you will need much more info than you will get here.)
You ask about "ratios" do you mean design FACTORS?
Length will depend on desired use and accomodation.
Breadth is typically close to length/3.
Draft depends on hull form and intended displacement. A V-bottom boat will have greater required draft (all else being equal) than a flat bottom.
After that, I would need to know more of the reasons as described above. Finally, my own area of experience is sailing dinghies, pulling boats and small motor boats. I merely quote above some rules common to all of these. You may also be better posting on the Motor Boat Forum.
