davidmh
I want to descale the engine over the winter and plane to do by circulating the mixture through the block with a small pump in a bucket, returned the mixture to the bucket. I have read that this can be done. I know I need to remove the anode from the block before I start. I will also need to remove the thermostat. On the Bukh the thermostat is mounted on a housing on top of the block and seals with a rubber O ring fitted around the thermostat.
1. If I take the O ring off the thermostat and then fit just the seal into the housing will it seal . Have any of the Bukh owners done this, maybe you have done if you have had a thermostat fail shut and have needed to run the engine.
2. I need a small pump for the Rydlyme, I will have mains power, I feel a low volume pump would be adequate as it simply needs to keep the mixture circulating. Any suggestions on a pump, Lidl, Aldi. Machine mart?
3. Would it be any benefit to use warm/hot water.
4. How long would you run the pump for?
Look forward to the forum comments
David MH
David MH
