winsbury
Thanks that video is excellent - feeling much better about it now; hopefully I just have to turn it around and not remove it this time but it is certainly good to know for the future. Mine is in a locker rather than the bilge so not so easy to pump out so it will be sponges and bucket at the ready then.
As to mounting the transducer, this was done by previous owner so don't know the quality of the work but judging by everything else Ive had to fix it could well be done badly. Its mounted inside the hull - not through hull - and appears to be epoxied in place with loads built up around the sides so it will be a real pig to remove so I will probably just leave it there. The hull is solid grp so no core or double skin issues that could be interfering. If I do need to put a new one in I'll almost certainly get one of those oil bath mounting systems as that seems to get rid of any possibility of air pockets and allows for servicing but sadly no such system is in place at present.
