winsbury
So after 9 months of refurbishment works, plumbing, wiring, welding, carpentry, glassing, rerigging, coppercoating etc etc we launched this weekend at last - hurrah !!! Many thanks to all those that have responded to my various questions over the months.
No leaks so I had an ear to ear grin however it soon became apparent that the nasa depth reading was bouncing all over the place and unusable, and the speed/distance system, a vintage 80's VDO Sumlog, seems to have given up the ghost too. Both were tested before launch and seemed okay so am a bit niffed to say the least.
The Nasa manual points to possible electrical interference although none of the other electronics are showing any signs of interference but unplugging the solar panel reduces the random readouts on the depth finder as does disconnecting the charging system from the wind generator but neither completely eliminates the spurious readings. As for the Sumlog I suspect the paddle wheel might have some excess grease from when I changed its O-rings but cant be sure without removing it from the hull fitting.
This leads to several dilemmas:
- Do I have to lift her out again to check/change the paddle wheel - there is access from inside but I have no idea if the top of the mounting tube is below the waterline so worried if I undo it she'll quickly flood. Also how to determine if its the paddle wheel or the display that has the problem, ideally with everything in situ
- Is there any special form of decoupling/screening/suppression required on the Nasa depth system known to work
- Will a new combined Nasa speed/distance system suffer the same interference issue ( assuming that's what it is and not a 'proper' fault.)
- Should I just bin the ancient gear and invest in a new n2k depth/speed/temp sensor and if so what one will interface with the Lowrance HDS 5M gen 2 that I have.
