Gary Fox
N/A
deleted
I asked a question which got answered at this end, you used to be able to delete posts but apparently now we can't.deleted
You can't delete a post properly like you could back in ye olden daysThat was cryptic
Should be easy for men of your calibre. It was a question relating to BSP threads, and the answer was 26mm.Intriguing!
We all want to know now what the answer was, so we can guess the question you posed.
Why do you assume LittleSister is a man?Should be easy for men of your calibre. It was a question relating to BSP threads, and the answer was 26mm.
Why do you assume it's an assumption?Why do you assume LittleSister is a man?![]()
I will try and make it less enticing!"deleted" always spawns a thread of responses. Better to edit it to say "I miss Maggie" or "Why do we still have 2nd class post?" or something.
As there are unsettling levels of mystery and intrigue in this thread already, I feel I should state that I have met LittleSister and he is, indeed, a man.Why do you assume LittleSister is a man?![]()
So 3/4" bsp overall diameterShould be easy for men of your calibre. It was a question relating to BSP threads, and the answer was 26mm.
Spot on! For all their blarney and bluster, distraction techniques and obfuscation...you were the only one who knew the answer!So 3/4" bsp overall diameter
When did you meet her????As there are unsettling levels of mystery and intrigue in this thread already, I feel I should state that I have met LittleSister and he is, indeed, a man.
I think he has a hole in his boat and he wants to know what thread he needs to fill it. The thread has moved on from the original question, though - to take the Michael aka piss.I thought we had to guess the question ?
