Ian_Edwards
The cockpit table on the Southerly 46 is a cunning device it folds up and then drops down into the cockpit floor, using a mechanism akin to an ironing board. However, this means that it is exposed to the elements and the recess in the cockpit floor often fills with water when the drain gets blocked.
The table has started to delaminate, probably because it has been wet for extended periods. I’ve started to deconstruct it for repair, and apart from a bodged attempt to seal it with what looks like Selaflex by the previous owner, I found square section aluminium rods embedded in the table to take the table leaf hinges.
View attachment 40567View attachment 40565
These are probably the source of the initial leak, the aluminium has corroded and expanded, it also made getting the set screws out very difficult. I broke two, No 2 posidrive bits and had to drill 7 of the 24 setscrews out.
I’m thinking of removing all of the aluminium bars, which I guess are there to strengthen the table leafs, and replace them with epoxy thickened with micro fibres, cast into the recesses in the foam core. I’ll then drill pilot holes in the epoxy and fix the hinges with say 1 ½ inch, A4, No 10, CS self-tapping screws.
I’ll glue the teak face back on with seawater proof PVA adhesive.
Will the epoxy/microfiber mix be strong enough?
Is waterproof PVA the best adhesive to use glue the teak back on?
Is there a better approach?
