deisel heater
searover
3 Feb 2004
Hi all you nowlegable ones, out there, does anyone know if you can mount an eiberspacher deisel heater on itside instead of going straight down like on a lorry floor. the reason i ask, is i cant find anywhere to mount the thing the right way, but i have put it on a fireproof bulkhead, on its side, it does seem to work ok without anything horrible happening, i do recomend these things they are super , anyway i wont bore the tears off of you all .but iwould appreciate, any comments regarding this way of mounting cheers all in antisipatoin....
sailorman
21 May 2003
Here or thertemp ashore
on my Co32 i made a fixed right angled bracket bonded to the deck Hd in the lazerettethe heater was affixed to this by wing nuts from a similar bracket fixed to the heater.
made removal very easy, as u didnt even need to see what u were doing, just by feel.
the main reason for moving the heather was that it was "Yard" fitted & placed in the easiest access for the fitter / engineer. it took up a goodly part of a locker
<hr width=100% size=1>Mines a Crocodile sandwich & make it Snappy
searover
3 Feb 2004
Hi chaps thanks for taking the trouble to answer. so i take it then i can mount this unit on its side with no problem. both the air intake and the exhaust is fed to the outside of the boat. so i should sleep easier now then chers for the info again Regards ...
cliff
15 Apr 2004
various
The eberspachers can be mounted on their sides provided the glow plug is still uppermost but.............. your unit will be lucky to see out a couple of seasons due to damp and internal corrosion as a result of the combustion air inlet no longer acting as a drain when the unit is off. mount it the proper way - make up an "L" bracket to hold it.
searover
3 Feb 2004
Ok i will do that , it sounds sence to me. ill do just as you recomend, these things are too dear to ruin through bad instalation . Thanks for taking the trouble to respond ...Regards
