richardabeattie
Is it OK to use the water produced by my dehumidifier to top up my batteries? Can't see why not!
What about water from a condensing tumble dryer?
You can't. It's quite simple, the water condensates against a evaporator. This water is coming from the air that is pulled through. So most of the dust in that air also sticks to the evaporator (because its wet) and ends up in the water.
So the condensate is far from pure. Hence why not. As Vic says. the money saved would be minimal and if it damages the batteries it would be even a negative saving.
Except that distilled water will be condensed and collected in such a way that excludes dust and other contaminants.Both are condensed water vapour, so there should be little difference between distilled & dehumidified water, other than perhaps the temperature at which the water vapour or steam is produced.
these days as most water is not hard anymore people just use tap water
Consider yourself lucky you don't live in Southern England. Most tap water has rocks in it!!
It varies enormously, even local supplies can vary.
I worked for a while in Tunbridge Wells. Water was pumped into opposite ends of the system from two different sources. One source was quite hard, the other very much less hard.
As the pattern of water usage varied during the day so the hardness where we were varied.
Dust and dirt certainly , although such solid cotaminants could be filtered out with ease.Therefore the water picks up the Co2 in the air and turns acidic adding to the acid in the battery plus all the dust and dirt washed out of the air is not helpful also
but CO2 is not highly soluble ( 1.5g/1000g) and the solution is only very weakly acidic, pKa = 6.37, anyway.
The effect on a strong acid solution, such as battery electrolyte, will be virtually none and most of the CO2 will be lost back to the atmosphere.
Distilled water gets produced in a closed system without ambient air present. The dehumidifier has plenty of air present as its job is to dehumidify it.... Therefore the water picks up the Co2 in the air and turns acidic adding to the acid in the battery plus all the dust and dirt washed out of the air is not helpful also. You save pennies and destroy pounds.
