tidclacy
Dare I say it but I have a Proper Rocna and have used it extensively on the East Coast, Holland and France. Never had a problem and have great confidence in it.
and asked her if she still wanted to help. Er......no.......![]()
I would bite the money bullet and go with a Spade or a Rocna quite willingly, except that the size guides don't really encourage me to go significantly down in weight, which is what I'm really looking for. I'm always a bit cautious because of the extra windage of the two masted rig.
Have you considered an aluminium Spade? ...around half the weight of a steel one.
Edit: It would really need to live on a bow roller or in an anchor locker though, as Spade's aren't great on deck.
Seriously the answer is a self stowing anchor and an electric windlass.
Obviously not got her trained - she should work that end of the boat and you stand at the other - shouting!
I have indeed, but not for long. I was put off by price and by the kinds of considerations mentioned by Charles Reed, plus some hints of doubts about shank strength. Also, I don't have an anchor locker and and don't plan to make the major alterations needed for he bow roller.
What I really need is an infallible (on every bottom), vastly strong, 7kg anchor that can live on deck in chocks, comes in at under £300 and is guaranteed never to let me down in any way. Should be simple, I would have thought........
But as far as I am concerned, this thread, so far, and the people who have kindly contributed, have helped me to think this thing through. I really appreciate that.
The plan is that when I can no longer use the boat it will be taken over by my nephew on my husband's side, who is a dinghy sailor, but getting really interested. I am delighted, as was my husband when we made the arrangement, because I couldn't imagine selling her to a stranger. Anyway, I suspect I'll be soldiering on with the trusty CQR and let him install what he chooses when his old Aunt is out of the way at last. (He's a lovely bloke by the way and a pleasure to have on board. I don't think he has any assassination plans at the moment)
Be aware, Spade no longer recommends using an aluminium version as your main anchor, sees the quote below from the UK Spade supplier January 2016
“They (Spade Anchor / Sea Tech & Fun USA the new Spade Manufacturers ) no longer recommend aluminium anchors as main anchors because of a problem with bending shanks particularly when using all chain rodes”
Also see http://www.spade-anchor.co.uk/sd_range1111.htm Their description of the uses of an aluminium spade
Main anchor for fair weather coastal cruising (with normal seabeds)
How do I know?
I have managed to bend 2 aluminium ones since 2004, now using the Steel version
I don't think so. She is a sensitive soul and, anyway, I don't do shouting, although I suppose I could learn.
No more electrics, please (even if I could afford to put that setup in place) At least, not until I have got to grips with the electrics I already have, which may take the rest of my active life. My dear husband was a chartered electronics engineer and knew all this stuff. I have sometimes wondered if he could draw me a wiring diagram, using the glass on the table at a seance. I could do with one. (What an awful woman I am)
Of the 28 boats I've watched anchor in the last few weeks, only 4 have set their anchors properly (reverse to F5 minimum).
As for worries about auto-resetting after a change of tide stream, I'm of the old school. I don't expect that. Instead, I do what countless generations of seaman have found advisable - I keep an anchor watch around changes of tide. It's my responsibililty....
I'm generally wary about putting myself forward on the forum (sensitive to the written rules and unwritten etiquette) but if you need help...
Consultation that doesn't involve getting tools out is generally charged by the pint rather than the pound too![]()
Bru - thank you. In fact I knew your previous boat and may have exchanged greetings with you and your wife in the past. In fact I did think of contacting you earlier in the year when I had a mysterious electrical problem. That got sorted out with the help of a friend (I learned a lot in the process) but I have your contact details and you are first on my list to call when, (not if) the electrons start misbehaving again next time.![]()
charles_reed; Of the 28 boats I've watched anchor in the last few weeks said:Some of us have saily boats, and actually use them as such.Is there any particular difference in the force applied on an anchor by an engine, and the force applied by the wind? Maybe the much vaunted "New Generation" anchors are only suitable for motor boats? (Flac jacket ready).
