VicS
Fortunately each battery already has an isolation switch so for me the simplest solution is to replace my 1/2/both/Off switch with the Bluesea. All cables already in place and it avoids a redundant switch or hole in the panel
If you already have separate battery isolation switches then surely all you have to do is replace the 1,2,B switch with a simple on/ off switch to parallel the circuits in an emergency. You certainly do not need the dual circuit Bluesea switch
