clifford worley
I have a 3GM30 which has developed an oil leak around the rocker cover, what is the best way of resealing the arm. it appears from pictures there is only an O ring on the shaft.
I will check that the breather is clear, replacing the rocker gasket is a real pain to actually fit and retain it in place. I eventually used gasket maker last time I replaced it. I have Viton O rings so will go out on the weekend and attack the problem.Replace the o ring on the decompression lever,
Check the breather in to top of the rocker cover is clear.
Best to replace the rocker cover gasket when you have it off.
I've owned the Kingston 580D since 2015 and 800 hours are on the hour meter it's actual age ( the motor) is a mystery. It doesn't use a lot of oil when I fix the leaks . They started with the fuel pump ( no kit available ) replaced then the rocker cover developed a ever so small leak which is enough to make a mess, that fixed I have obviously dislodged the O ring on the decompresssion lever. I have a good seal on the filler cap another Viton O ring. Your advice is much appreciatedJust wondering if you are getting blow-by up the valve stems to cause oil to pass the O ring. If you succeed in sealing the decompression levers, you might get oil coming out of the oil filler cap instead.
Any other symptoms ? How many hours on the engine ?
This help? https://www.jeanneau-owners.com/Manuals/3GM Engine Service Manual.pdfI now have the problem of removing the shaft from the rocker cover, do you know how they come out?
Can someone explain to me .
How do I remove the shaft from the rocker cover to replace the O rings.
Photos would be interesting.
I will take a pic of a 3 GM here in Japan and post tomorrow.
Also talk to the mechanic.
He is pulling one out right now.
gary
