gonfishing
Hi All
I have now looked at an Aq171 4cyl dohc engine and 280 leg, and have been made aware of some of the inherrant problems i.e needs to be fully tuned all the time and particular attention to cam belts and drives but this will fit my boat nicely so still a possibility.
I have also looked at an Aq155 with 290 drive not sure if this outdrive will be suitable it looks a bit on the big & heavy side, what are the pro's and con's of this set up?? guess that will require the full change over transom plate and bell housing etc I may be wrong ???
And finally having a look at an Aq 145 with 280 leg this week, this is the 4cyl single ohc job, again it will fit the purpose so is there anything to look out for on this set up ??
I could go the 3lt glx route with 280 outdrive but that's quite an undertaking and will probably over capitalise the boat
So price etc all about the same so if this is the route you had to take what would be your choice????
cheers
Julian
cheers
Julian
