Decent USB Charger from 12V?
Thanks, all. Yes, some interesting suggestions. I hadn't seen a 2x2.1A charger before, so that's worth investigating.
I'm not sure about the "can't charge through a data cable" assertion, though. I do know that some cables are power-only but I've never had the reverse situation.
As usual, things are more complicated than you would expect: http://en.wikipedia.org/wiki/USB explains something about this, but: yes, apparently if you want more than 0.5A out of a charger, your device and the charger may have to "negotiate" and agree to provide the full 1A or 2.1A. Or the device may just take power promiscuously, depending on whether it has implemented the correct protocol.
Has anyone come across the same kind of 2.1A charging capability but not in a "cigarette lighter" format? Ideally something like a USB 5-port hub, with 12V input and multiple 2.1A charger outputs.
Alternatively, I could just find a ciggie charger that works (your 4.2A one looks favourite, Nigel) , then re-skin it and plumb it in to the cupboard under the chart table.
Or I could just stop faffing about, and go sailing.
I know little about Apple products. We have Lenovo and Acer laptops. Each company produces 'car chargers' with cigarette lighter-type plugs for insertion into 12V sockets. They work perfectly.
Would the OP's problem be resolved by simply buying the right branded product?
Isn't that what I posted??
They are made for both models of iPad connectors. Mine works with no problem.
Thanks! They must be new as, despite the obvious need, they were not available this time last year. The only directly-installable 12v USB socket at that time was from Blue Sea at about £25, which was too much for me. I have a handful of lighter-socket adaptors (similar to the Griffin one posted above) awaiting modification - I can now cross out that job and buy a couple of these instead. Excellent.
...I'm not sure about the "can't charge through a data cable" assertion, though. I do know that some cables are power-only but I've never had the reverse situation.
Sometimes devices will only charge at 500ma with a data cable. I had that today with a 'cheap' USB car charger (2A rated) and I recognised the slow charge as the phone gave a message about media connection present. When I used the cable I mentioned, fast charge was enabled. Some devices have quirky behaviour and the internet is full of both good and misleading info on the wonders of USB charging.
Fair enough. I have used the retracting cables - since they do a good job of keeping things neat - but I've just bought a couple of supposedly "high power" micro-USB cables (short ones, again in the hope of eliminating the USB Rats Nest problem), so will see if that improves the charging rate of existing kit.
We'll probably just about get used to all this and then they'll introduce another "standard".
One thing I will say is that the availability of solid-state power devices in the past few years has had a HUGE impact on cost and size of adapters (240V as well as 12V). We never had it so good.
Do bear in mind that the one from FR is only a single 2.1A outlet, so yes I would buy two.
How many iPads do you think I have? :)
Actually, I plan to eventually have both USB and lighter-socket next to each regularly-used bunk, so I will have several, but it's more about location than total number.
many get caught out by that one - data cable, only 0.5amp; charging cable up to 1.8 amp (though the latter level is not covered by the USB universal spec). You see them trailing into mobile phone shops complaining that their charger doesn't work (usually samsung). There are a pair of cunningly twisted wires in the charging cable. USB3 is even more complicated, having two power levels of 150 and 900 milliamp (for simultaneous data) and 1.5 amp for power only. I'd stress it's NOT the charger but the cable.
Not really, it is a fully compliant USB port - it's Apple who are perverting the standard and suggesting you can use an inappropriate supply to charge their products.
To be fair, it's not just Apple. It's pretty much all smartphone and tablet manufacturers, and I believe the EU recently enshrined it in law for products sold here.
Apple originally designed the iPod to connect by Firewire, which includes a much beefier power supply as standard. But demand to use it with PCs which didn't routinely have Firewire ports (unlike Macs) meant they switched to USB.
Griffin yeah. Expensive but they kick out over 2amps and they're well made plus tiny. I bought two to keep on the boat to charge camera, phone, iPad, gopro etc.
To go somewhat off-topic, I visited a really cool company today (www.displaylink.com) and was told that they are working with a bi directional USB interface that can provide even higher current over USB (data and power cable) - to the extent that you will be able to drive a 12 inch LCD panel over USB alone. So, 4 amps+.
Before long I'll be starting my VP2003 with an iPhone app. Hopefully it will remember to open the water inlet first.
Haha! Of course! There's an APP for that!
Downloaded an Android app for my Samsung S2 (search "charging current to get a choice of 2) and it tells me the configuration of the charger.
It is sensitive to the cable, too, apparently my retractable cable only supplied 816mA while my "high power" one delivers 1138mA from the same charger.
Lots of fun to be had testing all the charger/cable combinations now.
I bought a new Anker (!). Anker seem to be a serious company that understands chargers. I bought a dual charger that has port for iPod and port for other. Have a look on Amazon Up to 4amp from one port.
As an aside I also bought an Anker portable battery charger which has eliminated the anxiety of the phone going flat as the end of the day
TudorSailor
