Ian_Edwards
I have two dead Li Ion battery packs off an 18V Chines power tool.
I've taken one apart.
They each have 5 18650's in series, in a flat pack. The design looks, superficially OK, the control circuit is sensing each cell individually.
I've measured the voltage across each cell:
1 3.77V
2 0.49V
3 3.78V
4 3.76V
5 3.79V
TOTAL 14.66V
Four questions:
I could use a bench power supply and try try charging number 2 battery, I can control both the voltage and the current with the power supply.
I could try charging the whole bank with the same power supply.
I could replace the faulty battery with a similar one.
I could replace all 4 batteries with new 18650s.
Replacing all 5 batteries the obvious safe choice, but that's a lot of work. I can buy 18650'd with tags already spot welled on, so I wouldn't have to solder directly on the cells.
Just trying to Charge the number 2 is lot easier, the pack hasn't been used for at least 2 years, and has had very few cycles.
Any comments?
1 3.77V
2 0.49V
3 3.78V
4 3.76V
5 3.79V
TOTAL 14.66V
Four questions:
Any comments?
