gonfishing
the starboard battery bank of 3 x 110amp batteries are only lasting 4/5 hrs before voltage drops below 18 volts. These are all new and have been swapped out with a proven set of batteries with the same result. I have had a DC clamp meter on the system and with everything on, that would be on at anchor we draw a maximum of 11 amps,when the fridge compressor is running, average current draw is 5amps otherwise. With everything switched of there is no current draw,so apparently no leakage. I have checked the terminals to the starter motor and alternator and they are all clean and making good contact. This set up has worked perfectly in the past 3 years but now all of a sudden this problem has popped up. I am now at a loss as to what the problem can be, so any ideas out there I would be most grateful, I have spent dys on this and it is driving me mad!!!! I cannot use the boat with this problem so would like to get it sorted asap so that IF and When the weather breaks here in Wales I may get to use the boat!!!!
Look forward to the replies.
Regards
Jules
Regards
Jules
