Talulah
write to Nigel Musto.
dont bother with the underlings
google "musto hpx lifetime promise"![]()
I believe Nigel sold out long ago.
Surely if this happened in use you would just whip the rope out of the self tailer and unload the rope, think this would be much quicker than rushing around trying to find the isolator.
Now if it happened when the winch was unattended that would be a whole different matter. In fairnes to Harken have you discussed this problem with them? I am sure they would want to know about this.
A couple of days ago we were motoring up the river to get the boat hauled out.
For no reason the port electric winch just started turning. Luckily we did not have the sheets attached otherwise we may have had major problems. We had to turn off the power to the winches on the main electrical panel.
The winches are Harken type 56's with 2 speed push buttons. No one was near the buttons.
I am presuming the problem lies in the buttons as they are the only part which would complete the electrical circuit to turn it on but I have no idea why they turned on as it has never happened before. I have since turned the power to them back on and they seem to work fine but obviously I need to know the cause before I can load the winches.
Any suggestions?
Has this happened to anyone else?
Naysayers who use electric winches for going up masts...take note!![]()
Have you got a contact email for Nigel?
You would not have fallen as, of course, you were attached to a second safely line .......you were, weren't you?
Obviously Harken think it is ok.. haven't heard a thing from them all day![]()
What about Oyster? Would they help?
I was once sent up a tall mast at about Mach 2 on a huge Lewmar hydraulic winch. It was only years later that someone mentioned to me "What would have happened if the winch failed to stop"......... well the answer to that would be that I would have fallen over 100feet to my death after the winch had snapped the line I was on.
Or been extruded through the mast head fittings?![]()
Strangely enough Oyster send out a couple of advisory notices a year to ll owners made up of feedback from the owners and things they notice owners ordering.
I received a notice today and part of that notice is reproduced below.
During 2011 Lewmar sent out a series of advisories to highlight the
importance of regularly inspecting any deck switches, and the
need to change these out if there are any signs of deterioration to
the switch.
A deck switch, like most pieces of equipment fitted to a boat, is not
a ‘fit and forget’ item. We would like to remind everyone to carry out
the regular inspections, as recommend by Lewmar, paying particular
attention to the rubber boot. If this rubber boot is looking worn, shows
signs of cracking or has any holes, then these switches need to be
changed out immediately.
Lewmar have indicated that every 3-4 years consideration should be given to changing out your deck
switches – but visual checks will confirm if wear and damage means they need replacing any sooner.
We hold the Lewmar deck switches in stock. Other deck switches can be ordered in. Please contact
Oyster Customer Services customerservice@oystermarine.com if you require replacements.
Seems unlikely, as it sounds like this was a while ago. Single halyard always used to be the norm for anyone I ever sailed with until recently. For many it probably still is.
Since when did the Laws of Physics change?
Anybody foolish enough to go up a mast on one line deserves to fall; anyone who sends another up a mast on one line deserves to live the rest of their lives with the consequences.
Forget bad seamanship, just utter stupidity.
