npm108
I've had a good look on Google but can't find any similar posts.
2007 D4 225s that have been working perfectly, except randomly hitting this issue.
Key On wait for gauges to power up and fuel pump to prime. Start engine ok..
After engine start and as soon as gauges run through their needle sweep engine hesitates and shuts down. Attempts to restart met with hard cranking (like no fuel). Only way to fix is to turn off the key, wait 1 min and then try again and mysterious issue vanishes.
Has only happened with warm engines 2 hours after use.
Start battery voltage is 12.6V
First time starboard engine was running, started port engine and during needle sweep both shut down!
Second time I was flushing engines on the hard, starboard engine hesitated on sweep but remained running...flushed for 5 mins and switched off.
Went to start port engine and stalled on sweep. No restart until key was off for 1 min.
Fuel is above 1/2 tank, no EVC faults indicated.
No issues once running with gear shifting etc and engines make full revs/power.
Any ideas ...
Any ideas ...
