VicS
Can I ask VicS, will a piece of annealled flattened copper plumbing pipe do as a basis for a copper washer, or is the copper too thin for this purpose?
Thanks,
Mike
A little on the thin side I think, esp modern stuff
Thanks,
Mike
Hi VicS, and Hi Pete,
I've been using plug 6 in your diagram, not 3. On my boat I can't get at the starboard side of the engine so have never seen plug 3 or the top of the drain tube. Must admit I never thought of annealing the copper washers though. Thanks for that.
Yes Pete, with using the Pela I just stuck a thin metal rod down the dipstick tube.
Thanks both for your thoughts
Mike
Looking at VicS drawing again, it gives the impression that you are looking at the port side of the engine, but this is not the case, you are viewing it from the starboard side, the side I can't get at.
Mike
My boat , a Dufour Classic 30, had beeb re-engined with D1-20 a year before I bought it. I don't know what the arrangements were with the original engine, a 2020, I think, but I found that practical access to the secondary fuel filter, the oil filter and the oil draining tube was non- existent, so I simply cut an aperture in the bulkhead between the engine space and the head, and installed a Lewmar hatch, 300mm x300mm, if I remember correctly.Ah, ok, that makes sense.
I too have a bulkhead hard up against the starboard side of the engine; the boat was originally built for a different one. However, I was able to reach down over the injector pump etc to attach the PVC tube to the drain pipe, and now I don't have to go back there again.
If you can't reach that area at all, how on earth do you change the oil filter?
Have you considered using a remote filter kit? You could put it somewhere easier to reach - and facing down, instead of the stupid sideways position that spills oil everywhere!
This is mine - note also the end of the sump drain tube next to it (plugged with a bolt):
You can't really see them in the picture, but there are a couple of holes into which I slot a pair of brass rods, then spear a plastic bag onto the rods to make a catching basket for the old filter and the small amount of oil that drips from the head when it's removed. After screwing on the new filter, I unhook the bag, seal it up, and bin it. Much easier than clearing up a bilge full of oily newspaper
The kit I used is this one, although I will say that the elbows included feel a little cheap, and in retrospect I'm not a huge fan of using jubilee clips here. There are others available with swaged hydraulic-style elbows.
Nappies or incontinence pads are a much better medium for controlling spilt oil.It's only relatively recently that I found out that the pipe from the bottom of the sump was for draining the pump - from a previous post from someone last spring I think. I've only had a brief look for it using a small mirror and a torch. However I'll investigate this further now.
Removing the filter is a real pig! I end up with the backs of my hands scratched, and black oil everywhere. I now line the engine bay with old newspaper and use "Marigolds".
Thanks,
Mike
Heat them on the stove. A heat gun will never do it. You might also use a butane blow lamp, but it's not advisable to store such a device on a boat.When I bought my B34, it was surveyed on the hard. It needed the sail drive gaitor replacing amongst a list of other things. So as part of the engine service I removed the oil using the sump plug, capturing the old oil in a plastic bowl. The washers were stainless steel but with a Rubber (or similar) insert. I replaced the sump plug using the same washers. However, oil dripped from the the sump plug, very little on the hard but once the engine was used (around 5 hours) I had a plastic take away container just overflowing. I got replacement washers (as close to those I had) emptied the oil and refitted the sump plug with the new washers. Ran the engine up and it was clear that the sump plug as still leaking. So I emptied the oil once again and refitted the sump plug with some copper washers, agail there is a drip from the sump plug but not as bad as previously. from the comments above I think I may need to anneal the washers before using them? So once again I have to remove the oil to be able to anneal the washers, unfortunately I don't have a heat gun able to heat the washers to red hot on the boat.
I have just discovered that I have, in essence, duplicated a post that I actually posted in 2016!My boat , a Dufour Classic 30, had beeb re-engined with D1-20 a year before I bought it. I don't know what the arrangements were with the original engine, a 2020, I think, but I found that practical access to the secondary fuel filter, the oil filter and the oil draining tube was non- existent, so I simply cut an aperture in the bulkhead between the engine space and the head, and installed a Lewmar hatch, 300mm x300mm, if I remember correctly.
I can now attach the 12v oil pump (from Lidl, under €30), and extract the oil in about 60 seconds., and easily change the filters.
Next I intend to divert the fuel supply pipe through the bulkhead, so that I can mount the primary filter in the head, thereby making filter changes much easier, and also providing space to possibly set up a parallel filter arrangement, making life even easier.
I was was a little reticent about making the latter change on aesthetic grounds, but I have just seen some interior photos of an Archambault 31 with the primary filter in the head, so I intend to go ahead with it over the winter.
