Sea Change
That would cut in to rum drinking time though...Be a nice little job in the evening, when you're at anchor![]()
I got luckyThere's nothing like a good skip hunt is there?
I did a lot of this a while back and found that nice sharp wood blades in a jig saw did the trick. Used a squeezy bottle and water with washing up liquid to lube it, also stopped the melting problem. Tidied up the edges with a belt sander. That was 10mm. Much easier to cut thicker perspex than thin, as less likely to crack. Don't remember getting any cracks in about 30 panels.
This is PBO to be fair so it makes sense to lean towards a bodge rather than buy, even if I do agree with you.Depends on how much you like to bodge things i suppose.
There’s a post on these forums somewhere from someone who worked at Lewmar (who make port lights etc. ) and I believe he said Acrylic is what they use and Polycarbonate scratches moments after you finish the job. I may be misremembering that but he was pretty clear on what Lewmar use and why.Perspex is acrylic, which is UV resistant but not particularly impact resistant. Lexan (polycarbonate) is less UV resistant but more impact resistant
It is possible to be practical without bodgingThis is PBO to be fair so it makes sense to lean towards a bodge rather than buy, even if I do agree with you.
For you, maybeIt is possible to be practical without bodging![]()
... Next thing you'll be telling me I wasn't supposed to use the piece of perspex I found in the marina skip!
From way back, cutting aircraft windshields to size, (think VERY expensive.. so a bit nerve shredding..) there is a real risk that a hand saw might start a crack because of the 'possibly' uneven application, whereas a power tool is more consistant.Does nobody use a handsaw any more except me?
I had to replace an acrylic sliding hatch, so I cut the old acrylic (damaged at the edges only) down to make an acrylic washboard. Ordinary wood handsaw going carefully. I then used a block plane with a good sharp blade to get absolutely smooth edges - definitely better than I could achieve by filing - and put a subtle little bevel on the corners. It doesn't seem to have been too unkind to the plane blade (I was expecting to have to resharpen after, but it did a few more jobs OK first). Not sure if this is bodging, but the result doesn't feel like it.
Lot of assumptions there. No suggestion by the OP there is anything wrong with the one he has already given that it has been replaced by wood ones. one pass through a table saw, a bit of polishing and job done. Exactly what I did with the one on my Bavaria 37 which was then 8 years old in the Med sun. 10 euros to the workshop for use of the saw. Quick quotes for 2 500*600 10mm acrylic around £140 before cutting the angles and polishing.Sounds like a plan...
Buy a persepx cutting blade, carefully cut the old (probably scratched, clear, brittle persex at an angle Perfectly straight and parralel.
Assuming it didn't break.... Sand the cut edge with 60 grit, progressively coming down in grades to 600/800, then polish with cutting compound. Taking care to keep the edges perfectly straight and aligned, to it forms a seal.
Or, order a couple of pieces of nice new, bronze tint (gives a bit of privacy) perspex, cut to size, polished edges and ready to fit.
eeny meeny miny moe...............![]()
Quite, the bloke is on his boat in Portimão, so likely limited options on tools.Lot of assumptions there. No suggestion by the OP there is anything wrong with the one he has already given that it has been replaced by wood ones. one pass through a table saw, a bit of polishing and job done. Exactly what I did with the one on my Bavaria 37 which was then 8 years old in the Med sun. 10 euros to the workshop for use of the saw. Quick quotes for 2 500*600 10mm acrylic around £140 before cutting the angles and polishing.
Also worth considering cutting 70/30 so the bottom part can be left in when sailing.
Indeed, see below. You don't know the condition, but it's very unlikely it's going to be "as new". He may not have a table saw, or access to one (good suggestion though).Lot of assumptions there.
On what do you base the assumption that the OP needs 2 500*600 panels ? Seems very, very unlikely he has a single washboard, 1000*600*10mm !! Besides, it's nothing like £140No suggestion by the OP there is anything wrong with the one he has already given that it has been replaced by wood ones. one pass through a table saw, a bit of polishing and job done. Exactly what I did with the one on my Bavaria 37 which was then 8 years old in the Med sun. 10 euros to the workshop for use of the saw. Quick quotes for 2 500*600 10mm acrylic around £140 before cutting the angles and polishing.
This is the OPs boat yachtsnet.co.uk/archives/sadler-290/sadler-290.htm 1000*600 for the companionway does not look far out. This is a sample quote for a single piece with no cut and no polishing perspexsheet.uk/clear-000-perspex/ so £150 for finished job of 2 pieces with a 45 degree cut and polished edges including delivery would not be far out. If his current unused one piece acrylic washboard is in good nick a few quid to a workshop and a bit of work to attach a batten would do it - just like I did.Indeed, see below. You don't know the condition, but it's very unlikely it's going to be "as new". He may not have a table saw, or access to one (good suggestion though).
True PBO spirit!I got lucky. The marina in Portimao were changing a bunch of signs and the skip was full of big pieces of perspex.
They were also fixing up some of the pontoons and I got some lovely hardwood planks which had been thrown away as offcuts.
I found a piece of perspex(?) in a telephone box.Goodness, I didn't know you were supposed to polish the cut edge.
