PaulRainbow
I bought a small angle grinder,
one that could be held and used in one hand, for such a job. I considered trying to make some sort of conical backing pad but in the end just used the ordinary flexible backing pads and a coarse sanding disc ( the grinding disc was far too aggressive) and did the "repair" from the outside anyway, although I started with a layer of biaxial glass cloth on the inside laid up against peel ply supported by a flexible pad taped to the outside![]()
That's exactly what i used for the tapers, although i did put a small taper on the inside as my hole was two inch dia'. Rather than peel ply i cut a piece out of a 4 pint milk "bottle" and stuck it to the hull with tank tape.
