Cutlass bearing help
emmalina
6 Nov 2014
Thailand
www.lantamarineservices.com
I once found resin bearings in Malaysia some 10 years ago. I bought a long piece and have been chopping and using every haul out @2 years This year I find I have no more but my stern tube seems to be a non standard size. Anybody know where I could get a 2.5" by 1.75" shaft and long 7" bearing . It seems all the 1.75" shafts all have 2 5/8 housings. I purchased a resin bearing advertised at 2.5 x 1.75 but the 1.75" is actually 45mm so has more play than the one I just removed.
Tranona
10 Nov 2007
One possibility is to use a 2 5/8 brass shell cutless and have the outer shell machined down to fit your tube. The bearings come with 2 3/8 shell as well so there is ample wall to do this. I have juts done similar with a 30mm that comes with either 40 or50mm shell and my housing was 43mm.
Alternatively have a composite bearing made of Maritex. h4marine.com/Maritex01.htm This is the UK distributor, but the material comes from Australia.
You might also want to look at your set up as changing bearings every 2 years suggests something is seriously wrong - either the material you nave been using is not suitable or your shaft is either out of lone or not supported properly.
Poignard
23 Jul 2005
South London
Have they decided to continue? I heard they had stopped making them and someone else was taking that part of the business over.
I didn't know that. It's more than 20 years since I fitted one of their bearings in my boat and I made a note of the details in case I ever needed to buy another.
