jimi
Boat has a Cunningham but its not rigged, Is it worth doing so?
Yes, if you want to put some effort into getting the best out of your sails upwind.
Being able to flatten the main properly can mean you can sail efficiently instead of having to reef. A good outhaul and kicker system helps too.
If I've got a fractional rig with adjustable backstay, does'nt tightening the backstay do the same job? Or is it different?
The cunningham will pull the maximum depth of camber forward more than the Halyard can.
For example on my decent quality 3 year old loose footed main, I cannot get the best sail shape that I want because the material has already stretched and my sail "hinges" at the top half and at the end of the battens.
The Cunningham does one thing - and one thing only - it moves max. draft depth fore and aft! ... and this moves as the wind strength changes.
As someone else pointed out, if there is friction in the luff, tightening the main halyard will tend to change the top end of the sail shape, but do little at the lower end. The Cunningham will do the whole lot.
It doesn't flatten sails or replace reefing. However, good sail shape and trim will delay the need to reef by reducing drag and increasing lift.
sam![]()
I wonder if a cunningham would tame my weather helm ...
Saggy old sails - they have more experience than the helmsman!
Why would the vang be important going upwind? To counteract flex in the boom?
How would you rig a cunningham to a previously uncunninghamed 28ft boat? A new cringle about a foot above the tack? Then what?
Thanks![]()
If you've got an old jib on a roller, then rolling more of it up and pulling the draft forward in the main with the cunningham works well on some boats.I enjoy a bit of racing and even when cruising I play with all the sail controls on my boat. But my conclusion is that most of them are pointless unless a/ you are interested in the last tenth of a knot and b/ have good enough sails to take advantage of the controls.
As for the cunningham., are your sails nice new laminate jobbies? Do you have nice Dynema halyards so you can hoist the main and then use the cunningham to vary the halyard tension without it stretching too much? And what about the jibs because there is little point in messing with a cunningham on the main of a boat with a saggy old jib on a roller.
