D
Deleted member 36384
On another thread its been suggested by Flaming that a Blade Jib is a good choice for cruising yachts; indeed Flaming advises that new racing yachts haven't had Genoas for years now.
It is my plan by the end of next year to replace all the sails on my tub. So, on a Rival 41C, Masthead Rig, 10 Tonne at 41' LOA, 36' LWL, cutter rigged, would cruising laminate blade jibs be a good idea on the inner and outer forestays; main would also be in a cruising laminate. I think they would be when the wind gets up into No3 territory, so I am really querying low wind performance where I currently believe a big Genoa would be better.
What do think about cruising and blades in general and doing away with big Genoas? Clearly, the Rival weight and hull shape reflects old design and technology and I think blade jibs would not work on this type of hull design, however, maybe it would, as Flaming suggests VMG is likely to be better, although the Rival heels over and doesn't have the form stability of a fat arsed yacht.
I am intrigued.
I am intrigued.
