captaingb
Which cruising yacht above 40 ft and currently in production can point at or better than 30 deg to the true wind?
2 interesting reply so far ....
ahahah .... not at all. just trying to find out if such a yacht exist or not so I can have it on my shopping list.
I think thats probably correct though andymcp makes a very valid point - it is possible to sail closer but as implied by the polars, progress drops off very rapidly. and of course the polars are either theoreticals or real data taken useing new high tech sails as in YW tests. what you will get with your average cruising sail after a years use is different again.
way I look at it, a close winded boat always is an advantage. even if you have to crack off 5 degrees to make life comfortable, you are adding that 5 degrees to a smaller number in the first place so you are still sailing closer than you might be in another boat. and if you have to sail to windward when cruising ( it sometimes happens) a close winded boat does ensure the unpleasantness lasts for a shorter time. plus a short thrash to windward in 10 knots true is always good sail tweaking fun.![]()
Thanks for your reply. I'm thinking along the same lines in trying to estimate how many more sailing hours versus less engine hours I could achieve with a very close winded yacht.
