Adrian62
Hi what size and type of cruising chute do you recommend for a westerly konsort
That is so on my list but I can’t always take my boat out of the water each year to service so it seems a no go unless there is such a thing as a service free folding/feathering.If you don't have a folding or feathering prop, consider one of those instead for the extra speed it will give you all the time not just downwind.
(apologies if this was a bit of a big assumption )
(My boat is also 29' and the prop gains me 0.7 knot consistently.)
Normally I get a diver to scrub the hull and put anodes on but this year even that wasn’t an option so I had to take the very second rate solution of earthing a wire and hanging an anode on it over the stern.Don't you have any anodes?
When you are here in Mogan, and if I am here, I can dive on the hull and do the anodes for you.Normally I get a diver to scrub the hull and put anodes on but this year even that wasn’t an option so I had to take the very second rate solution of earthing a wire and hanging an anode on it over the stern.
