Cross tide (river) pontoon berth
Just looked at my Duncan Well's book, Stress Free Sailing and he describes your situation. An alternative to springing off, is to take a slip from the outside quarter, run it away from the stern to the pontoon, then drive ahead against this line while steering off. The boat will not move forward but the bows will pivot out. You need to fender the inboard quarter well as it will push against the pontoon. He does mention that it will get you 90 degrees out.
And a convenient video from BritSail: -
Would that work when there is a 2.0-2.5 knot current pressing the yacht against the pontoon?
What has the OP got to lose by trying it, the boat will either turn or not. If the OP steers off at the same time, it will drive the stern into the pontoon and may increase the force to pivot out and round.
Isn't this the "spronging" of which the original post was seeking an opinion about?
I've only seen someone try to do something like this once, alongside the main walkway in Falmouth Haven. He couldn't get the bow out far enough to safely depart forwards and eventually sprung off conventionally, motoring out in astern.
The video makes it look very easy, but there doesn't seem to any wind or tide pinning the boat into the berth.
It only took 23 posts to get there. Clearly I need to work on my descriptions! :-)
I'm hoping that the thruster along with starting with the sprong on the outside quarter before transferring the load to the outer miship cleat to complete the turn will make it more effective but until I get out there and try l dont know how much shove it will give me.
I have a feeling I shall remain pinned to the pontoon in anything above a knot
Leaving a boat against a pontoon with a regular 2kn tide pressing her on seems desperate to me. Won’t the flotsam and jetsam and weed get snagged round the rudder?
Will the fenders cope with a Gale and a surge tide pressing her on ?
Nobody has mentioned prop wash. My boats stern reacts quite well to a few very short bursts on the prop. So depending on what way it is pointing it will have a greater/lesser effect on my ability to get the stern off a pontoon.. By having a rope to the bow, a few bursts on the prop & the stern would come off quite easily.
“Spronging” is a new one on me - might give it a go next time I feel like experimenting.
Confess that I thought the OP had repeatedly (and carelessly) spelt “Springing” incorrectly. Apologies for doubting you OP!
Nil to add to previous advice.
If the tide isn’t at its strongest, or there is negligible wind (or in your favour) you may be able to combine bursts of prop wash against the rudder, synchronised with bursts of bowthruster to make her go sideways. Works for me getting my high freeboard against the wind
It is the latest lockdown game
You make up a new name & slip it into a post as if it was quite normal & it sends everyone rushing to be the first to type it into google. Then , not being able to find it they start using it, as if they knew what it meant all along. :unsure:
It's the first I have ever heard of the term but it is used in the video as well, in their captions, so it appears to have some nautical provenance.
The layout of the pontoons is such that its fairly well protected from debris and the worse of the weather whereas a lot of other boats will be beam on to wind and waves (small) in a SW gale. A surge tide or gale from the South or West will be blowing the boat off. The pontoon is also fendered so while clearly not ideal Im not concerned over the boats safety
Note what they say about helm position and also read the comments below, which may help.
what page in the book?
May I ask where this mooring is, that might help get more advice from those local.
Page 58., Technique 9, Tide on the beam, boat being blown on.
Do you have the book? It’s not that difficult to find considering pages 56 and 57 are dedicated to departing with combinations s of wind and tide pushing the boat on.
It is worth noting the graphic on page 58 with the photograph of the method on page 59, regarding g the stern line length and distance from the quarter. Then compare with the video in my earlier post. Also two different hull shapes, both doing this maneuver.
My Rival 41C struggles to spring off in astern if there is any wind on the bows due to the high aspect of bows.
Thanks, I have the book, just goes to show that I haven't read it all. Perhaps some reading in the coming month ready for when I can get out again.
Might be interesting to try to work out the maths on the forces involved on the GRP at the rear quarter, being forced against the pontoon if trying to “spring” out against the tide. And to be successful the corner has to move along the pontoon being subjected to these forces.
Saw on a 10m boat with the water centre of effort mid way along there would be a nice 5m lever on the tide effect as soon as the side is a cm off the pontoon. And side forces of water massively stronger than windage, anything below a hurricane.
My brain can’t fully work the maths, but the stern sprong and engine is also pulling the stern corner inwards, whilst the corner scrapes along the pontoon if successful, popping any fenders out.
Best tried in a school boat, not your own.
This season I will be using a cross tide pontoon berth with a circa max. 2.5 - 3.0 knot tide on the ebb that will pin me to the pontoon. Should I want to leave on the ebb my current plan is to sprong myself off using a stern spring attached to the stern cleat furthest from the pontoon with the help of a 75kg thruster. However to make life even more interesting I will need to turn through 90 degrees in order to clear the boat in front so if needed I was thinking of attaching the sprong to the midship cleat and then on to the stern cleat so I could unhook this part way through to aid the turn.
Up to what ebb rate do you think this would work ignoring any wind effects?
Boat is a shallow fin Moody 36 drawing 1.45m with a 40hp engine.
Think about how much force it takes to create 3 knots of side movement.
Get a different slip. I've seen some bad acidents that just weren't worth going out. 1-2 knots, sure. 3 knots, go home.
The good news having looked into it in more detail today is that I have over estimated the ebb which will actually be more like 1.5 - 2.0 knots max at springs so provided Im not being blown on I should be able to sprong off apart from a couple of hours when its above 1.0 knot
Spronging works for me, springing off never did unless conditions were perfect.
The advice is to steer into the dock but I found if you want really big angles you have to do a bit of judicious steering into the turn.
Great thing about spronging is that all the action is a the rear of the boat so the singlehander can helm and take charge of the line conveniently. It also keeps the rope short. I always use a floating ski line so it can be cast off and ignored, if busy.
I'm not keen on the idea of trying to transfer the pivot to a centre cleat halfway through though; I think there is scope for a YouTube video in that one.
