Crimping swage sleeves using thimbles
coopec
N/A
23 Nov 2013
Very shortly I will be installing the stanchions, wire rope and netting.
The cable will be threaded through the stanchions and tension-ed up using bottle screws.
Two questions:
  • Should I use one or two swage sleeves. (I like two for safety)
  • How do I crimp them? Is there a special tool or do I use a hydraulic electrical cable crimper.
I would appreciate your advice.:D
wire-rope-attachment-rope-loop-ends-steel-slinging-using-thimble-crimp-sleeve-d-illustration-7...jpg
lustyd
27 Jul 2010
These days you ought to be using cord rather than bottle screws. No idea on the staging, sorry
coopec
N/A
23 Nov 2013
Mine are Sta-lok, something I have been pleased about several times when I needed to unthread bent stanchions.
Sta-lok has some nice looking gear but I bet it is not cheap. If I had these I wouldn't have to use swages but at $143ea. they are out of the question.:cry:
eyJidWNrZXQiOiJ3ZWItbmluamEtaW1hZ2VzIiwia2V5IjoiaGFyYm91cnNpZGVjaGFuZFwvaW1hZ2VzXC9wcm9kaW1nXC85NDI2XzEuanBnIiwiZWRpdHMiOnsicmVzaXplIjp7IndpZHRoIjo0ODAsImhlaWdodCI6NDgwLCJmaXQiOiJpbnNpZGUiLCJ3aXRob3V0RW5sYXJnZW1lbnQiOnRydWV9fSwidmVyc2lvbiI6IjIyYjYwZTIxMWY5OWU1NjNkYzZkMDIwMGE4Y2FkMDNhNzU3M2NiNTcifQ==
TSB240
17 Feb 2010
Ìf I didn't have access to a hydraulic crimping tool I would buy a cut to length wire with a roll swaged m6 threaded bar at one end and a fixed clevis fork at the other.
Jimmy Green have a useful site to explore alternative fasteners that will fit an m6 threaded roll swage.
An M6 roll swage will pass through most guard rail stanchions eliminating the need to remove them to replace the guard wires.
They make a reliable strong connection which in my opinion is more suited than stay locks or cable clamps on a safety critical item.
RunAgroundHard
20 Aug 2022
The crimp in your picture is ugly. I would not want such an unsightly termination on a boat I owned, especially if DIY. Mine are swaged bottles screw rods, eyes. The threaded rods can pass through the stanchion holes, the swaged eyes are shackled onto stainless loops on the push pit, pull pit. Works for me.
Also, I have seen cut fingers on the type of crimps you are suggesting from the end wires. Sometimes seen sealed with heat shrink, but again, an ugly solution to a crap choice of fitting.
Post No5 would be a better way than what you initially proposed, especially for DIY.
coopec
N/A
23 Nov 2013
Thanks for that but I have bought all the gear I need. As far as bottle-screws are concern there are only 8 on the 43ft yacht so they won't be too dominant. I've made up the 900mm (3ft) stanchions so they are non-standard and I will be installing safety netting as well. Some people reckon safety netting is ugly but I think it is great!
DownWest
25 Dec 2007
S.W. France
One swage is enough, but, you must use the correct tool, not an electrical terminal crimper.
I made my own from a 20ton bottle jack (£40) and some bits of RSJ and 40x8mm flat bar. The tooling is two bits of 16x16 clamped together and drilled, then bits welded to ensure they close square. I use it up to 5mm wire.
If you send an e-mail address, I can send a photo.
coopec
N/A
23 Nov 2013
coopec
N/A
23 Nov 2013
I am rapidly coming to the conclusion that I should get them professionally crimped by someone with the correct gear. Alternatively I may borrow a purpose made crimper if they are straight forward to use. (I am being very careful because a life may be at risk):cautious: (I have sent you my email address)
RunAgroundHard
20 Aug 2022
  • How do I crimp them? Is there a special tool or do I use a hydraulic electrical cable crimper. ...
Thanks for that but I have bought all the gear I need. ...
Talurit can be contacted directly for advice on strength. You have indicated concern at saving life by avoiding failure, so I would go straight to the horses mouth for advise. https://www.talurit.com/service/advisory-service/splicing-instructions/
They specifically state to contact them for the required instructions. https://www.talurit.com/products/fe.../copper-ferrules/tcu-copper-turnback-ferrule/
I have sailed many yachts, and for the safety lines that have had a Tulurit sleeve, I have usually seen single ferrules, tubed shaped after compression, not with the ridges that you have shown in you OP image.
Iliade
27 Apr 2005
Shoreham - up the river without a paddle.
www.airworks.co.uk
Ditch the bottle screws and use a lashing that can be cut in an emergency.
I have a cheap chinese hydraulic crimper that will set the threaded rod fork terminals well enough for use as a guard rail. It cost me about £120, so probably still cheaper to pay a pro to roll swage them if you only need eight.
