HinewaisMan
If you have an older Crewsaver lifejacket fitted with the Hammar Automatic Inflation, I’d suggest you read on.
Mea Culpa, my Crewsaver N150’s are no spring chickens, well over 10 years old, and haven’t been used much over the last few years.
But today’s job was to check all the life jackets on board, make a list of what needed replacing and do an inflation teat.
One of the Crewsaver’s deflated almost immeadiately.
Investigation showed that the plastic seal around the Hammar had perished and split. The lifejacket is useless now.
Out of the 8 lifejackets I carry, the THREE Crewsaver 150N’s which had Hammar fitted were ALL suffering the same problem.
Thankfully, these are the only jackets with the Hammar, and when I replace them, the new ones won’t have the Hammar. Like my other 5 jackets which were fine.
So if I may, I would suggest that if you have an older Crewsaver with a Hammar fitted, check it before you use it again!
