Why does it happen? Are there some better acrylics than others ? Two boats I've just looked at have crazed (crazy?) windows but the third didn't and they were all late -80's build.
Are you sure they are all acrylic? Yes it will craze with age and UV exposure. However, polycarbnate which looks superficially the same won't although despite being infinitely stronger is softer and can scrape more easily. However, generally preferred overall for boat windows.
As said, it's due to UV over the years. It's said that the strength is reduced, however when I replaced some crazed windows some years ago, I thought I would see how strong they were, so put one in a vise and tried to break it - it did eventually break but only with the help of a 3lb club hammer and a lot of effort. I was certainly surprised.
Thank you, I was going to ask if it's OK to remove them to replace their seals and to put them back, pending replacement at a later date; it seems they should withstand gentle handling..... and I bet they're not cheap !!
If you are going to all that trouble, replace them. Any signmaker will cut them out to pattern. Just make your decision on material - polycarbonate is a little more expensive. The biggest hassle with replacing windows is not cost of materials but time and getting them to seal properly.
uv damage mostly.
I have that problem with my forehatch.
I've been advised that a simple canvas cover left over it when boat is not un use will seriously limit the crazing.
