Iain C
I took a Forgen 500 off my old boat and was going to put it on my new one and I have a few questions. I know they don't give much output, I'm just using it as a simple trickle charger.
Firstly, it's already sat on the top of a plain s/s pole which in turn I want to attach to my pushpit. Can anyone point me towards a cheap, simple bracket system that allows this? I basically want something to go around the upper and lower horizontal rails with U-bolts or similar to go around the generator mast.
Secondly, my house batteries are a bank of two pretty chunky batteries...I assume it's as simple as putting the +ive croc clip on to the +ive terminal of the first battery, and the -ive croc clip on to the -ive terminal of the second battery?
Thirdly, I have a 20W NASA solar panel that I intent to fit too. It gives a formula for when you don't need a controller, and as my panel output is well under that percentage compared to the capacity of the house battery bank, I wasn't planning on fitting one. However, if I just fit the solar panel onto the battery bank as well as the Forgen, am I going to end up with some bizarre solar powered windmill contraption and flat batteries or will it all just do it's own thing as intended?
Thanks in advance!
Thanks in advance!
