merjan
I am replacing the old bolts on a split shaft coupling - both those four that squeeze the coupling around the shaft and those that fix the coupling to the gearbox flange. I am wondering what sort of steel is the correct material to use here. I suspect A4 stainless steel wouldn't be the best as they might shear. The engine is a 1GM10 and the shaft diameter is 1". Any advice would be much appreciated!
