I have a good Henderson Mk 5 bilge pump which I would like to fit to my 25ft boat. If I mount the pump in the starboard cockpit locker can I run the outlet through the starboard side of the boat? I cannot site the (nylon)fitting higher than 15 inches above the waterline, this means about 6 inches below the rail so the fitting will occasionally be submerged. Failing this I would have to run the pipe through 2 bulkheads to the stern and even then it looks mighty inaccessible. The boat has an outboard and the bilges are very dry, the pump is therefore for emergencies only. The lockers drain into the cockpit which is itself provided with 2 drains. What is the correct way to fit a pump like this?
Thanks in advance for replies.
